форум kia ceed > Общество > English speaking forum
About transmission-oil-filter-changing
Автор Тема: About transmission-oil-filter-changing  (Прочитано 131194 раз)
nobodyasusual
Hi my Russian friends.
I want to learn something about ceed automatic transmission.
My car is 2012 ceed motion diesel Automatic Transmission.
Here in Turkiye, I see that they DON't change transmission-oil-filter while changing the trans. oil.
This is a bit weird for me. Because I am thinking that it is a necessity that the transmission-oil-filter should be changed.
So, I decided to change the oil filter on my own/myself. Therefore I need your help. And I have some questions about this.
1. Where is the exact location of transmission-oil-filter? Can I see it if I unplug the oil-pan only?
2. Is there anyone who has the same car with me, and who has changed the transmission-oil-filter?
Please help me.
Thanks in advance.
Kalender.
m11st
1. Remove the engine protection.
2. Turn off the head 24 and the automatic transmission drain plug Drain the oil .
3. Turn off the head 10 all bolts Automatic pan and use a screwdriver to gently remove pallet automatic transmission - it is in the sealant .
4. Turn off the head 10 3 bolts and remove the filter , the filter magnet round 2-3 must be removed to wash them and put in a new filter.
« Последнее редактирование: Апрель 12, 2015, 09:17:30 am от m11st »
nobodyasusual
Thank you very much for your answer.
Leeks_70Rus
  • Russian Federation Томск
    ODO 160 km
Hi. Yellow is a magnet, pink is a nut of fastening of the filter. To remove the filter otkrucheny nuts and pull him down. The magnet should be cleaned so that it was clean.
