Автор Тема: led problem... :(  (Прочитано 132332 раз)
makrisd1
  • Greece
Hello everybody!!!
I installed a pcb of leds on the dome like that:
http://img26.imageshack.us/my.php?image=4241836067osvetlenieintc.jpg
but i have a problem with this.  :(
when i have the button (which opens the dome lights with the opening of door) pushed, and all of the doors are closed, the pcb of leds continue lighting but a little... but normally should be tottaly closed... The leds consume less current... can i do something to fix the problem?
Sorry for my english ;)
Udalec
Look, it can to you the help.
http://www./index.php?section=handmade&item=equpment&article=nav_light
"Автомобиль не роскошь, а средство передвижения"
( О. Бендер )
Udalec
Excuse me.
( О. Бендер )
makrisd1
  • Greece
Excuse me.
the link doesn't open  :(
anton_sw
  • Estonia Таллинн
Hello everybody!!!
Hi!
Usual lamp has approximately linear voltage-current characteristic.
And diode (led) has characteristic like this: http://en.wikipedia.org/wiki/File:Diode-IV-Curve.svg
If you doesn't need led "soft start/stop" you may add serially connected resistor. (calculation: Resistor[Ohm]=(12/LedOpeningCurrent)-LedResistance) This will reduce current in the circuit.
If you need led soft start/stop: it is not so simple to make led behave like usual lamp. But there are some solutions:
You should use for example microcontroller which will generate impuses like that:
My solution: you have lo learn some special materials about leds.
One of them: http://datasheets.maxim-ic.com/en/ds/MAX16832A-MAX16832C.pdf
Sorry for my english too  :)
Regards, Anton.
