Автор Тема: Underfoot lights  (Прочитано 132559 раз)
makrisd1
  • Greece
How can i connect the dome lights with the underfoot lights which i want to place... the purpose is because i want to open underfoot lights together with the dome lights!!!
BRiWS
« Ответ #1 : Март 08, 2009, 12:02:13 pm »
Are there underfoot lights in Ceed??? Do you mean that you want to light the ground near the doors when they are open? The only way i see is to put a wire across all the roof, the bars which hold the roof, then the door etc... Because there's a switch near the dome light which turns it off, and i think this switch should also turn off underfoot lights.
anton_sw
  • Estonia Таллинн
Hi!
I think that this scheme explains the connection points:
Yellow is the possible underfoot light.
Regards, Anton.
« Последнее редактирование: Апрель 23, 2009, 00:25:03 am от anton_sw »
     9   настроить
