Коды ошибок (DTC) на 2.0 л бензин
Автор Тема: Коды ошибок (DTC) на 2.0 л бензин  (Прочитано 32278 раз)
Q
  • Administrator
    ODO 5000 km
    -Выданные: 42
    -Полученные: 182
  • Большой брат следит за тобой!
Коды ошибок считываются с помощью специального сканера.Информация предоставлена исключительно для ознакомления!
ABS > ESP
   C1101 Battery voltage high
   C1102 Battery voltage low
   C1200 Wheel speed sensor front-LH open/short
   C1201 Wheel speed sensor front-LH range/performance/intermittent
   C1202 Wheel speed sensor front-LH invalid/no signal
   C1203 Wheel speed sensor front-RH open /short
   C1204 Wheel speed sensor front-RH range/performance/intermittent
   C1205 Wheel speed sensor front-RH invalid/no signal
   C1206 Wheel speed sensor rear-LH open/short
   C1207 Wheel speed sensor rear-LH range/performance/intermittent
   C1208 Wheel speed sensor rear-LH invalid/no signal
   C1209 Wheel speed sensor rear-RH open/short
   C1210 Wheel speed sensor rear-RH range/performance/intermittent
   C1211 Wheel speed sensor rear-RH invalid/no signal
   C1213 Wheel speed frequency error
   C1235 Primary Pressure Sensor- Electrical
   C1237 Pressure Sensor - Other
   C1260 Steering sensor circuit - signal
   C1261 Steering angle sensor not calibrated
   C1283 Yawrate and Lateral G Sensor - Signal / Other
   C1503 ESP switch error
   C1513 Brake switch error
   C1604 ECU Hardware Error
   C1605 CAN Hardware Error
   C1611 CAN time-out EMS
   C1612 CAN time-out TCU
   C1616 CAN bus off
   C1623 CAN time-out SAS
   C1625 CAN time-out ESP
   C1626 Implausible Control
   C1643 CAN Time-out Yaw and G sensor
   C1702 Variant Coding
   C2112 Valve relay error
   C2308 FL(IN) Valve error
   C2312 FL(OUT) Valve error
   C2316 FR(IN) Valve error
   C2320 FR(OUT) Valve error
   C2324 RL(IN) Valve error
   C2328 RL(OUT) Valve error
   C2332 RR(IN) Valve error
   C2336 RR(OUT) Valve error
   C2366 USV1 error
   C2370 USV2 error
   C2372 HSV1 error
   C2374 HSV2 error
   C2402 Motor electrical
SRS-AIRBAG
   B1101 Battery voltage high
   B1102 Battery voltage low
   B1328 FIS-Driver defect
   B1329 FIS-Driver communication error
   B1333 FIS-Passenger defect
   B1334 FIS-Passenger communication error
   B1346 Driver airbag resistance too High (1st stage)
   B1347 Driver airbag resistance too Low (1st stage)
   B1348 Driver airbag resistance circuit short to Ground (1st stage)
   B1349 Driver airbag resistance circuit short to Battery (1st stage)
   B1352 Passenger airbag resistance too High (1st stage)
   B1353 Passenger airbag resistance too Low (1st stage)
   B1354 Passenger airbag resistance circuit short to Ground (1st stage)
   B1355 Passenger airbag resistance circuit short to Battery (1st stage)
   B1361 Pretensioner front-Driver resistance too High
   B1362 Pretensioner front-Driver resistance too Low
   B1363 Pretensioner front-Driver resistance circuit short to Ground
   B1364 Pretensioner front-Driver resistance circuit short to Battery
   B1367 Pretensioner front-Passenger resistance too High
   B1368 Pretensioner front-Passenger resistance too Low
   B1369 Pretensioner front-Passenger resistance circuit short to Ground
   B1370 Pretensioner front-Passenger resistance circuit short to Battery
   B1378 Side airbag front-Driver resistance too High
   B1379 Side airbag front-Driver resistance too Low
   B1380 Side airbag front-Driver resistance circuit short to Ground
   B1381 Side airbag front-Driver resistance circuit short to Battery
   B1382 Side airbag front-Passenger resistance too High
   B1383 Side airbag front-Passenger resistance too Low
   B1384 Side airbag front-Passenger resistance circuit short to Ground
   B1385 Side airbag front-Passenger resistance circuit short to Battery
   B1395 Firing loops interconnection fault
   B1400 SIS front-Driver defect
   B1403 SIS front-Passenger defect
   B1409 SIS front-Driver communication error
   B1410 SIS front-Passenger communication error
   B1473 Inflatable curtain airbag front-Driver resistance too High
   B1474 Inflatable curtain airbag front-Driver resistance too Low
   B1475 Inflatable curtain airbag front-Driver resistance circuit short to Ground
   B1476 Inflatable curtain airbag front-Driver resistance circuit short to Battery
   B1477 Inflatable curtain airbag front-Passenger resistance too High
   B1478 Inflatable curtain airbag front-Passenger resistance too Low
   B1479 Inflatable curtain airbag front-Passenger resistance circuit short to Ground
   B1480 Inflatable curtain airbag front-Passenger resistance circuit short to Battery
   B1527 Passenger Airbag on-off switch open or leakage to Battery
   B1528 Passenger Airbag on-off switch short or leakage to Ground
   B1529 Passenger Airbag on-off switch defect
   B1530 Passenger Airbag on-off switch instability
   B1620 Internal fault - Replace ECU
   B1650 Crash recorded in 1st stage only(Frontal - Replace ECU)
   B1651 Crash recorded in front-Driver side airbag(Replace ECU)
   B1652 Crash recorded in front-Passenger side airbag(Replace ECU)
   B1655 Crash recorded (Side - Replace ECU)
   B1657 Crash recorded in Belt pretensioner only
   B1658 Belt pretensioner 6 times deployment
   B2500 Warning Lamp
   B2505 Passenger airbag off warning lamp failure
FULL AUTO AIR CON.
   B1200 Humidity sensor open (High)
   B1201 Humidity sensor short (Low)
   B1202 Water temp sensor open (High)
   B1203 Water temp sensor short (Low)
   B1208 Intake potentiometer open (Low)
   B1209 Intake potentiometer short (High)
   B1233 In-car temperature sensor short (Low)
   B1234 In-car temperature sensor open (High)
   B1237 Ambient temperature sensor short (Low)
   B1238 Ambient temperature sensor open (High)
   B1241 Evaporator sensor short (Low)
   B1242 Evaporator sensor open (High)
   B1245 Air mix potentiometer open (Low) - Driver
   B1246 Air mix potentiometer short (High) - Driver
   B1249 Direction potentiometer open (Low) - Driver
   B1250 Direction potentiometer short (High) - Driver
   B1257 AQS sensor open (High)
   B1258 AQS sensor short (Low)
   B1259 AQS sensor fault
   B1264 Direction Potentiometer Open (Low) - VENT
   B1265 Direction Potentiometer Short (High) – VENT
   B1266 Direction Potentiometer Open (Low) - FLOOR
   B1267 Direction Potentiometer Short (High) – FLOOR
   B1268 Direction Potentiometer Open (Low) - DEF
   B1269 Direction potentiometer short (High) – DEF
   B2406 Air mix motor (Driver)
   B2408 Intake motor
   B2417 Direction Control Motor (VENT)
   B2418 Direction Control Motor (FLOOR)
   B2419 Direction control motor (DEF)
AUTOMATIC TRANSAXLE
   P0707 Transaxle Range Switch Circuit Low Input
   P0708 Transaxle Range Switch Circuit High Input
   P0711 Transaxle Fluid Temperature Sensor Rationality
   P0712 Transaxle Fluid Temperature Sensor Circuit Low Circuit
   P0713 Transaxle Fluid Temperature Sensor Circuit High Circuit
   P0716 A/T Input Speed Sensor Rationality
   P0717 A/T Input speed Sensor Circuit Low Input
   P0722 A/T Output speed Sensor Circuit - Open or Short(GND)
   P0731 Gear 1 Incorrect Ratio
   P0732 Gear 2 Incorrect Ratio
   P0733 Gear 3 Incorrect Ratio
   P0734 Gear 4 Incorrect Ratio
   P0741 Damper Clutch Open Stuck
   P0742 Damper Clutch Close Stuck
   P0743 Damper Clutch Control Solenoid Valve : Open or Short(GND)
   P0748 VF Solenoid Valve Circuit - Open or Short(GND)
   P0750 Shift Control Solenoid Valve-A Circuit - Open or Short(GND)
   P0755 Shift Control Solenoid Valve-B Circuit - Open or Short(GND)
   P0760 Shift Control Solenoid Valve-C Circuit - Open or Short(GND)
   P0765 PCSV-C(UD) Solenoid Valve Circuit - Open or Short(GND)
   P0880 TCM Power Signal Error
   U0001 Can Communication BUS Off
   U0100 No ID From ECU
   P0605 Check SUM Error
Beta 2.0L DOHC(EOBD)
   P0011 Camshaft Position-Timing Over-Advanced or System Performance(Bank 1)
   P0016 Crankshaft Position-Camshaft Position Correlation(Bank 1)
   P0030 O2 HO2S Heater Control Circuit (Bank 1 Sensor 1)
   P0031 HO2S Heater Circuit low (Bank 1 Sensor 1)
   P0032 HO2S Heater Circuit high (Bank 1 Sensor 1)
   P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
   P0037 HO2S Heater Circuit low (Bank 1 Sensor 2)
   P0038 HO2S Heater Circuit high (Bank 1 Sensor 2)
   P0076 Intake Valve Control Solenoid Circuit Low
   P0077 Intake Valve Control Solenoid Circuit High
   P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
   P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
   P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
   P0111 Intake Air Temperature Circuit Range/Performance
   P0112 Intake Air Temperature Circuit Low Input
   P0113 Intake Air Temperature Circuit High Input
   P0116 Engine Coolant Temperature Circuit Range / Performance
   P0117 Engine Coolant Temperature Circuit Low Input
   P0118 Engine Coolant Temperature Circuit High Input
   P0121 Throttle / Pedal Position Circuit Range/Performance Problem
   P0122 Throttle / Pedal Position Circuit Low Input
   P0123 Throttle / Pedal Position Circuit High Input
   P0130 HO2S Sensor Circuit (Bank 1 / Sensor 1)
   P0131 HO2S Sensor Circuit Low Input(Bank 1 / Sensor 1)
   P0132 HO2S Sensor Circuit High Input(Bank 1 / Sensor 1)
   P0133 HO2S-Sensor Circuit Slow Response (Bank 1 / Sensor 1)
   P0134 HO2S Sensor Circuit No Activity Detected (Bank 1 / Sensor 1)
   P0136 HO2S Sensor Circuit Malfunction (Bank 1 / Sensor 2)
   P0137 HO2S Sensor Circuit Low Input (Bank 1 / Sensor 2)
   P0138 HO2S Sensor Circuit High Input (Bank 1 / Sensor 2)
   P0139 HO2S Sensor Circuit Slow Response (Bank 1 / Sensor 2)
   P0140 HO2S Sensor Circuit No Activity Detected (Bank 1 / Sensor 2)
   P0170 HO2S Sensor System - Lambda Controller at the Limit (Bank 1)
   P0171 System Too Rich (Bank 1)
   P0172 System Too Rich (Bank 1)
   P0196 Engine Oil Temp. Sensor Range / Performance
   P0197 Engine Oil Temp. Sensor Low Input
   P0198 Engine Oil Temp. Sensor High Input
   P0230 Fuel Pump Circuit Malfunction
   P0261 Cylinder 1 - Injector Circuit Low
   P0262 Cylinder 1 - Injector Circuit High
   P0264 Cylinder 2 - Injector Circuit Low
   P0265 Cylinder 2 - Injector Circuit High
   P0267 Cylinder 3 - Injector Circuit Low
   P0268 Cylinder 3 - Injector Circuit High
   P0270 Cylinder 4 - Injector Circuit Low
   P0271 Cylinder 4 - Injector Circuit High
   P0300 Multiple Cylinder Misfire Detected
   P0301 Cylinder 1 - Misfire detected
   P0302 Cylinder 2 - Misfire detected
   P0303 Cylinder 3 - Misfire detected
   P0304 Cylinder 4 - Misfire detected
   P0315 Segment Time Acquisition Incorrect
   P0325 Knock Sensor 1 Circuit Malfunction
   P0335 Crankshaft Position Sensor Circuit Malfunction
   P0340 Camshaft Position Sensor Circuit Malfunction
   P0420 Catalyst System Efficiency below Threshold (Bank 1)
   P0444 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Open
   P0445 Evap. Emission Ctrl. System - Purge Ctrl. Valve Circuit Shorted
   P0501 Vehicle Speed Sensor B Range/Performance
   P0506 Idle Control system- RPM lower than expected
   P0507 Idle Control System RPM Higher than Expected
   P0560 System Voltage
   P0562 System Voltage Low
   P0563 System Voltage High
   P0605 Internal Control Module Read Only Memory(ROM) Error
   P0625 Generator Field/F Terminal Circuit Low Input
   P0626 Generator Field/F Terminal Circuit High Input
   P0650 Malfunction Indicator Lamp(MIL) Control Circuit Malfunction
   P0700 TCU Request for MIL On/Freeze Frame to ECU via CAN
   P1505 Idle Charge Actuator Signal Low of Coil #1
   P1506 Idle Charge Actuator Signal High of Coil #1
   P1507 Idle Charge Actuator Signal Low of Coil #2
   P1508 Idle Charge Actuator Signal High of Coil #2
   U0001 High Speed CAN Communication Bus
   U0101 Lost Communication with TCM
MDPS
   C1101 - Battery Voltage High
   C1102 - Battery Voltage Low
   C1103 - IGN Voltage Fault
   C1259 - Angle Sensor Fault
   C1261 - Steering Angle Sensor is not calibrated
   C1290 - Torque Sensor Fault
   C1603 - Derating (EPS thermal protection)
   C1604 - ECU Hardware Error
   C1611 - CAN Timeout Fault연
    C1616 - CAN Bus Off Fault
   C1617 - CAN Invalid Value Fault
   C1700 - Byte Coding Error
   C1702 - Variant Coding Error
   C1704 - ECU Failsafe Relay Fault
   C1705 - ECU Precharge Circuit Fault
   C2101 - Motor Relay Fault
   C2400 - Motor Fault
   C2401 - Motor Circuit Fault
   C2412 - Motor Short or Open
   C2413 - Motor Current Fault
IMMOBILIZER
   P1610 Non-Immobilizer-EMS connected to an Immobilizer
   P1674 Transponder status error
   P1675 Transponder programming error
   P1676 SMARTRA message error
   P169A SMARTRA Authentication fail
   P1690 SMARTRA no response
   P1691 Antenna coil error
   P1692 Immobilizer Lamp error
   P1693 Transponder no response error/Invalid response
   P1694 EMS message error
   P1695 EMS memory error
   P1696 Authentication fail
   P1697 Hi-Scan message error
   P1699 Twice overtrial
TPMS
   C1121 Left Front Sensor Battery Voltage Low
   C1122 Right Front Sensor Battery Voltage Low
   C1123 Left Rear Sensor Battery Voltage Low
   C1124 Right Rear Sensor Battery Voltage Low
   C1126 Vehicle Battery Voltage Low
   C1127 Vehicle Battery Voltage High
   C1300 TPMS ECU IRX not Responding
   C1312 Left Front Sensor Radio Frequency Channel Failure
   C1313 Right Fron Sensor Radio Frequency Channel Failure
   C1314 Left Rear Sensor Radio Frequency Channel Failure
   C1315 Rear Right Sensor Radio Frequency Channel Failure
   C1322 Left Front Sensor Over Temperature
   C1323 Right Front Sensor Over Temperature
   C1324 Left Rear Sensor Over Temperature
   C1325 Right Rear Sensor Over Temperature
   C1332 Left Front Sensor Fault
   C1333 Right Front Sensor Fault
   C1334 Left Rear Sensor Fault
   C1335 Right Rear Sensor Fault
   C1337 Left Front Low Frequency Initiator Fail Pulse Detected
   C1338 Right Front Low Frequency Initiator Fail Pulse Detected
   C1339 Right Rear Low Frequency Initiator Fail Pulse Detected
   C1341 Auto Location Failure FL
   C1342 Auto Location Failure FR
   C1343 Auto Location Failure RL
   C1344 Auto Location Failure RR
   C1351 Left Front Low Frequency Initiator Open/Short Failure
   C1352 Right Front Low Frequency InitiatorI Open/Short Failure
   C1353 Right Rear Low Frequency Initiator Open/Short Failure
   C1611 Vehicle Signal (VSS) Time Out
   C1616 CAN Bus off
   C1661 Receiver EEPROM Failure
   C1662 Auto Learning Failure
« Последнее редактирование: Март 30, 2008, 21:39:40 pm от Q »
Помни! Огонек в глазах может быть признаком тлеющих опилок в голове!!!
