форум kia ceed > Вопросы эксплуатации > Тюнинг (Модераторы: MAX F, MIK, Людвиг Аристархович)
Электрохромное тонирование?!?!
Страницы: 1 2 [3]   Вниз
Автор Тема: Электрохромное тонирование?!?!  (Прочитано 10688 раз)
S_S
    ODO 212212 km
dmvivanov
  • Global Moderator
  • Russian Federation Самара
    ODO 360000 km
« Ответ #31 : Июль 07, 2011, 13:56:39 pm »
Вот ответ китайцев на моё письмо. Тут ссылки на фото и видео, цены на продукцию и некоторые характеристики.
Subject:   Electrochromic glass Films for cars
To:   Dmitry Ivanov
Date:   06/07/2011 05:11 PM
Thanks for your email. We are the most professional manufacturer of  magic glass/film, please check the attached catalog for your  reference. Please check the demo videos at:
>> http://www.viddler.com/explore/citiglass/videos/
>> 1, Max size is 120cmx270cm, it can be applied onto acrylic too.
>> 2,  The electrical power consumption is very low, less than 0.3W/m2, it can be controlled by battery too.
>> 3,  it can work with any voltage with a transformer we provide.
>> 4, with a regulator/turning button, it can control the transparency.
>> It can be either a film or a laminated glass. If you don't want to replace the existing glass, the film will be a more convenient option. Please check the videos for help.
>> Black film is also available, please check this video: http://www.viddler.com/explore/citiglass/videos/50/
>> For you specially, we offer the best price for you to start the business:
>> 1, electrochromic film  (Max size is 120cmx270cm)
>> purchase volume 10 square meters to 50 square meters: USD720/m2.
>> purchase volume 50 m2 to 100 m2: USD650/m2.
>> purchase volume 100 m2 to 150 m2: USD600/m2
>> purchase volume 150 m2 to 300 m2: USD450/m2.  and the purchase volume is 1000square meters, the price will be the lowest: USD250/m2 only.
>> The film can resist -30C degree temperature in extreme weathers.
>> The thickness of the film is 0.375mm only.
>> Cleaning it is easy, with a soft cloth, it will not scratch it.
>> Payment term: By T/T telex transfer from banks, or Western Union.
>> For the samples, we have the following sample kits for sale:
>> Electrochromic film: 20x20cm, with transformer and control: USD350/SET.
>> LED Glass, size 30x30cm, with transformer and control: USD150/SET.
>> Magic mirror: 40x60cm, with customized photo provided by the buyer: USD150/pcs.
>> (Not including the shipping cost.)
>> Best wishes,
>> Ryan
>> CITIGLASS GROUP
>> Tel: +86 13839162024
>> MSN: citiglass@live.cn
>> SKYPE: citiglasschina
>> www.citiglass.com
>> Showroom of video demonstration:
Каталог забыл прикрепить. Чуть потёр для уменьшения объёма. В принципе всё написано тут почти.
« Последнее редактирование: Июль 07, 2011, 14:15:20 pm от dmvivanov »
S_S
    ODO 212212 km
« Ответ #32 : Июль 07, 2011, 16:09:26 pm »
Спасибо!
 Но дорого, примерно 20 т.р. за м2.
Из письма не понял: пультом управления и трансформатором оснащается каждый рулон?
dmvivanov
  • Global Moderator
    ODO 360000 km
« Ответ #33 : Июль 07, 2011, 17:28:19 pm »
Вкратце так:
Типа мы самые профессиональные изготовители. Посмотрите прилагаемый каталог и видео.
Максимальный размер листа плёнки 120х270 см, и столько-же на акрилле.
Потребление энергии очень низкое, менее 0,3 Вт на квадратный метр, поэтому может работать от батареи.
Работает с любым трансформатором, который мы поставляем.
Диммером можно регулировать прозрачность.
Можно преобрести либо плёнку, либо ламинированное стекло. Если вы не хотите менять стёкла, то лучше купить плёнку. Чёрная плёнка так-же доступна.
Дальше цены:
Объем покупки 10-50 квадратных метров: 720 баксов/m2.
50-100 м2: 650 баксов/m2
100-150 м2: 600 баксов/m2
150-300 м2:т450 баксов/m2
1000 квадратов: 250 баксов/m2.
Вся эта дребедень переносит такой экстрим как -30 по цельсию (что маловато :( )
Толщина плёнки 0,375 мм.
Чистится мягкой тканью, чтобы не царапать. (вот как со стеклоподъёмниками то?)
Дальше способы оплаты и образцы для бизнеса. Плёнка, светодиодные стёкла, зеркало с фотографиями.
S_S
    ODO 212212 km
« Ответ #34 : Июль 07, 2011, 17:53:56 pm »
Вот в этом и вопрос - сколько стоят эти приблуды?
Хотя при такой стоимость пленки существенной разницы уже нет.
dmvivanov
  • Global Moderator
    ODO 360000 km
« Ответ #35 : Июль 07, 2011, 19:02:40 pm »
Да что там эти мелочи. Сначала надо посчитать,исходя из размеров листов, какими размерами брать, чтобы 10 метров раскроить оптимально на максимальное колличество стёкол. Это будет по максимальной цене, плюс проценты при переводе, плюс доставка из Китая. Совсем не выгодно.)))
Гарик 43
  • Russian Federation г.Малмыж Кировская область
    ODO 39500 km
« Ответ #36 : Август 05, 2011, 15:19:24 pm »
никто не вкурсе, а сколько стоить та будет электрохромное тонирование если 2, например, стекла боковых передних сделать?
(Эт тоесть стекло которое с кнопочки затемняется). Сьемную не предлогать, имхо бред снимать одевать каждый раз
Гаи заставили тонировку содрать, чет совсем без нее плохо :'(
смотрел в инете, написано что от 7 500 - 32 000 $
это явный перебор!
Гарик 43
Страницы: 1 2 [3]   Вверх
     9   настроить
