Автор Тема: Battery cable  (Прочитано 128964 раз)
makrisd1
  • Greece
Do you have a photo about the battery cable which is located under the steer? i want to take voltage from the battery but there are a lot of cables and i don' t know which is the right!! what color is this?
I must tell you that your forum helps me a lot!!! Thank you!!
+ it is possible to take batteries from a suitable wire to the block of safety locks on the panel on the left side. Looking for what it is necessary +, if for the booster it is better to take from the battery, if for the signalling will approach from an ignition lock
makrisd1
  • Greece
Thank you!!! I know where it is located but i don' t know which is :( There are a lot of cables that are connected with the block of safety locks,but which is the + of battery? And something else... I have make the question again but i would like a better solution!!! I want to pass cables from engine to the passengers cabin... how can i pass them from the drivers side? (the left wing) thank you again!!!
To stretch a cable it is possible through the left side panel or near to the vacuum servo of brakes (at the left)
makrisd1
  • Greece
if you have some photos will be the best for me to understand better!!! Does anyone know which is the + cable of battery near to fusebox?
makrisd1
  • Greece
nobody knows?? :( :(
makrisd1
  • Greece
One photo i found with the cables
Photos unfortunately are not present, but + it is possible to take from a thick red wire
